Thanks Thanks:  4
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 125
Thread: #8938 - Jacob's Build
    Jacob's Avatar
    Rogers, AR
    After thinking it over, decided to remove the fuel lines from the upper R of the trans tunnel and put them back where I had them, along frame rail of passenger side. Still intend to install a driveshaft loop but just didn't think having the fuel lines there as a good idea. Appreciate Edwardb for making me pause and think!
    MK IV complete Kit - 1st time builder started Sept 2016
    Levy 306
    T5
    2015 Mustang IRS
    Power steering - Levy setup, Breeze roll bars, Thompson trunk box
    fuel injection, powder coating, sway bars, heater, wipers, 17 in wheels
    Jacob's Avatar
    Rogers, AR
    More progress being made:
    Got the motor and transmission this week
    Moved the fuel lines back to where I originally had them, passenger side frame rail
    Got the Russ Thompson signal seated where I'm happy with it
    Finally decided where to mount the master battery switch
    Got the gauges and switches laid out where I'm happy with them.
    Mounted the grab bar (that I shamelessly copied) from edwardb
    Now I'll take a break and drive the 37 Ford down to the "redneck riviera" for a few days!
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Any problems with how I mounted the inertia switch?
    Covered the dash with marine vinyl that has a nice pattern to it. First covered with vinyl faux carbon fiber, but was concerned about how it might hold up and if it got scratched it would not be fun taking all the gauges out. The small button on the lower side between the Tach and Speedometer is my safety switch that must be pushed in while starting, a manual neutral safety switch.
    Installed the dash grab bar (idea stolen from edwardb)...I have it braced to the 2x2 frame rail. I'll try to take some pics.
    Starting the wiring now and to be honest it's a bit more challenging than it should be but I'm slogging through it.
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Here is a pic of the bracing I built for the grab bar. It's 1/2 inch x 1/8 inch flatbar with extra bracing welded on and its real firm. This view is looking down from the heater box.
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Dash / Gauge / Switch wiring roughed in and tested most of the circuits and so far they all work as designed...even the Russ Thompson dimmer / flash to pass! Thanks to Edwardb for coaching me through this. Few pics below:
    Including this pic to show how the Russ Thompson hub fits. I still have about 1/8" to move inward. Also in this pic below the column is an LED momentary push switch that will act as a clutch safety switch, have to push it while turning the key to start. I didn't want to try to fabricate a clutch lever safety switch.
    This pic may show the grain of the marine vinyl cover that I used on the dash. I like the texture of it. I will cover this console box that contains the fuse panel and use SS button head screws to hold a vinyl carbon fiber cover.
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Catching up on a few items.
    Installed the set screw that will hold the hub adaptor in place.
    Slight set back. Seems when the motor was assembled the bell housing was intended for a TKO trans rather than a T-5. Was getting ready to start putting the motor and transmission in the car and after wrestling with the transmission by myself, decided to stop and measure bolt holes...so waiting on the replacement to arrive.
    Decided how I was going to open and close the footbox vents. Found some 24" throttle cables that worked out real well.
    I installed the drive shaft cage. Realizing others have a negative view of the one I installed, but I think it will be fine, especially given how I intend to drive it. Sometimes, cheap insurance is better than none at all.
    Almost finished with stuffing the wiring and defroster vents behind the dash. Can't imagine how those who use the Coyote manage to get all the wires back there? The space filled up fast.
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Dropped the motor in, so I feel like I might have accomplished something. Motor went in fairly easily, did it by myself and took about an hour and a good amount of that was getting the driveshaft to line up. Had the front wheels on the ground and the rear jacked up about a foot or so.
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Radiator installed. Using the Breeze radiator mounting system. Seemed to worked out well. Right now it's set at about 51 degrees with adjustment room to get to 56. (Please excuse if any of these pics are duplicates, but since photobucket hijacked my pics, I'm having to edit all previous posts).
    Got most of the power steering hoses fabbed up, power steering fluid cooler, reservoir mounted and only lack the line going from the bottom of the reservoir to the pump. A straight fitting will work better than the 90 that I have on hand.
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Trying posting photos using the Forum Albums...
    about to wrap up the electrical (still waiting on the FiTech system, so a certain amount of wiring is in limbo).
    Coolant plumbed
    Using this method to post pics is easy and better than trying to use photobucket!
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Trying to catch up with the last few items I've worked on:
    Relieved that my fabbed up air vent system wouldn't be too close to the exhaust header. Header isn't permanently attached since I'll still need to add the O2 sensor (once I get the FiTech system). Been waiting quite a while for it, but have been told its on the way. I will likely be asking for help wiring up the Fitech system, I am confused on the cooling fan and fuel pump wiring?
    Powder coated the Breeze roll bars with a 'chrome powder coating and followed with a clear coat. The finish is more like a ceramic coating on headers. I modified the roll bar by having an adjustable backstop on the rear of the roll bar. Likely because I welded too vigorously and the piping shrunk, but at any rate I can live with having it bolted up.
    Mounted the coil. Wiring temporarily right now. Once I know the engine will start I'll make the wiring neater.
    Plumbing done on the cooling system and the power steering system.
    Next is to remove the distributor and prime the oil pump and check pressure.
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Today I decided to cover the center console with the marine vinyl like I have on the dash. All went well until I took the shifter bezel out of the box and realized I have an oval shifter hole in the tunnel sheetmetal and a round bezel that leaves quite a gap uncovered.
    Levy 306
    T5
    2015 Mustang IRS
    You should have a fill panel for the trans tunnel cover with a circular hole in it. Of course after putting it in you will need to recover.
    Jacob's Avatar
    Rogers, AR
    Found that panel...I've gotten a bit lazy and think I know more than the manual!
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    The fix for the tunnel console wasn't too much of a big deal. Just put the filler panel in , filled in the void with the PC-7 (good stuff, an epoxy that can be sanded, but not easily), riveted the fill panel in and recovered the tunnel panel.
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Tested the oil pump today and with the electric drill I could get 55 PSI. Just waiting on the FiTech system to get here, wire it up and then I see no reason that the engine can't be test fired.
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    The Ignition Module is installed and the FiTech system is installed, wired and plumbed. I haven't set the system up with the initial inputs yet. Filled the cooling system and checked for leaks. So about all I need to do is put the side pipes on, get an assistant to standby with an extinguisher.
    I'm gonna list below my wiring details (mainly for my memory) but if anyone sees a problem or potential problem please let me know. I am using the MSD 6AL box and ready to run distributor.
    MSD Box
    Red - to IGN SW (orange IGN Feed)
    Orange- + terminal coil
    Black - - terminal of coil
    Green / Violet - to the Distributor (its a two wire)
    White - not used
    Gray - to tach feed and Blue wire from Fitech
    Ground - to frame
    FiTech
    Red - to battery, hot all the time
    White - to IGN Feed (same post as the MSD red wire)
    Yellow- to the green FAN SW wire at the radiator
    Blue - to gray of MSD box and the yellow tach feed
    Black - not used (for A/C), this kicks up RPM when using A/C
    Orange- directly to the in-tank fuel pump (not using the tan RF feed to the pump)
    I'll clean up the wiring once I make sure all is good.
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    After spending the better part of the last two days trying to start the engine, essentially found the timing was 180 degrees off. Should not have assumed it was close. A bit puzzled because MSD says the LED should be on when the ignition is in the ON position...it initially lights but then goes out. There was also some issue with the communication between the MSD box and the Fitech system (5 LED blinks and then off is a REV limit deal that when using EFI has to be disabled). I know I should have a video but ...
    Levy 306
    T5
    2015 Mustang IRS
    I feel your pain and eventual relief. Congratulations.
    Jacob's Avatar
    Rogers, AR
    Guess it had to happen...had (have) a small setback. Kept noticing a small amount of oil beneath the oil pan around the plug area, so I assumed either the gasket was bad or not tight enough...then decided to really look close with a magnifying glass and good lights. The weld around the oil pan near the plug has a pinhole leak. So just when I was about to wrap up the frame / motor / etc and get ready to put the body on, this happens. Once the alignment is done, it's ready to go kart.
    The resolution is going to be replacing the oil pan. I've come too far to attempt fixing a defective part and I don't want to be continually dealing with oil drops!
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Finished fabbing up my mechanical linkage, had heard no real good feedback on the standard throttle cable. Figured I better go ahead and address it now. Turned out ok. Short story doing it myself came in just north of $100, probably could have done it a bit cheaper, but all in all I'm satisfied. It would take more time now than I have but if anyone wants the part list I can put that together. I'm gonna move the coil off the firewall and onto the side. The arms allow for quite a bit of adjustment, so I believe it will work?
    Soon I'll trailer to the alignment shop and should be ready to try out the go kart? Just a few days from one year the start date.
    looking down toward the foot pedal, maybe it's clear how the throttle rod is routed?
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Asking for ride height opinions
    Tires are: Front 255/40 ZR17
    Rear 315/35 ZR17
    When I measure from the floor to the bottom of each frame rail corner, I get:
    FR 4 5/8" RR 5 3/4"
    FL 4 5/8" LR 5 11/16"
    Given these measurements what are the thoughts as far as adjusting these? Any and all help appreciated!
    Levy 306
    T5
    2015 Mustang IRS
    closer to 4" is typical. However without the body on it is not super critical at this point. Once the body is on you will have to reset and align everything anyways.
    Jacob's Avatar
    Rogers, AR
    Took the first go kart ride today. (trying to figure out how to put the video on you tube?)...at any rate, all was good. Got the alignment done and took it around the neighborhood.
    https://www.facebook.com/jacob.adcoc...0&notif_t=like
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Starting work on the body. Rolled the underside of the body with bedliner (realizing I'll likely get overspray on it later) and also applied acrylic latex caulk to each of wheel wells hoping this will allow some "cushion" for future rock pecks?
    The lighter black area is where the caulk was applied.
    Levy 306
    T5
    2015 Mustang IRS
    Good idea with the caulk. I did not do anything to the underside of my wheel wells and every time I roll over some loose stones and hear them pelting the underside of the body I cringe! You will be pleased you did that. Looking good.
    Nicely done... For the fender inserts I sprayed them with a rubberized spray to help w the rocks. I sprayed self etching paint, and them the spray on rubber. I got it from Lowe's, I don't have a lot of miles, but it went on nice. I also did the aluminum on the bottom of the car.
    Jacob's Avatar
    Rogers, AR
    Sorta of an update: washed the fiberglass parts with Dawn to get rid of the accumulated dust, then wiped down x2 with degreaser and then used 3M scotchbrite pads with abrasive cleaner (comet). Rolled the wheel opening lips to about 95% satisfaction. Then tried a test area with a DA sander and 120 grit disc to see how the gelcoat will sand down at the seams. The plan is to sand the seams down and then areas where the gelcoat is beneath the surface of the seam, grind those areas out with a dremel tool. Then use filler on the seams (rage gold).
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Uncurred Gelcoat problem
    I started today tackling the uncurred gel coat issue. Background on this...I was probing the seams with a pic and found 4 areas where the gelcoat is still soft (body was built August 2016). Discussed with FFR and they were very apologetic and we discussed how to proceed. In essence, grind the gelcoat until I stopped finding uncurred gelcoat, clean with acetone, backfill 95% or so with 3M HSRF and finess with body filler. So today I started with my dremel with a sanding drum and gently ground the areas out. Some areas were like veins and ran a bit before they cleared up. Two areas are pretty substantial. The photos below are the most serious location. Pretty sure it will all be fine after they are fixed.
    This will sorta give you an idea of how the gelcoat looks once the crust is ground off. The deeper red area is gummy and soft. This area was passenger side rear top corner.
    This is the area that is the most serious. Passenger top corner by the windshield post
    This is that area, with the gelcoat (uncurred) ground out. Note the blue spot that's my finger showing the 1/4" hole in the fiberglass (there is no fiberglass there and I did not grind it out, it just wasn't there), so I'll have to reinforce with more glass later.
    This is that area with the first hit of HSRF. I'll sorta grind this down and touch up with body filler if it doesn't need any more HSRF. As I went down the seam I found more uncurred gel coat.
    I'll let these 4 areas cure for a few days and start cleaning them up and get them ready for filler / sanding.
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Filled the area with HSRF and sanded flush with the surface then used rage gold to finesse the surface:
    Kept finding some raw gelcoat in about 4-5 areas so just decided I better grind out the seams. Interesting, the surface looked hard and felt hard, but when ground down, the passenger front fender had the most soft areas, so I had to be pretty aggresive, I kept finding pockets of raw gelcoat, Hopefully I got all of it:
    Then initially filled these voids with HSRF and will sand this off in a few days, then come back with filler:
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Continued working on getting the seams filled in and ready for primer. Installed the Finish Line louvers (95%). Trying to do as much as I can before putting the body on for door gaps, etc.
    This gives you an idea of how much needs to be removed to make the opening semitrical with grill fins:
    Opening needs just a bit more filing:
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Just in case it appeared that I haven’t been working on the car, I have been sanding and getting ready for the first body test fit. My computer died and I now have an iPad and not learning too fast how to post pics. Although the cold weather is keeping me out of the shop!
    Levy 306
    T5
    2015 Mustang IRS
    Kearney Nebraska
    Same here, the cold weather definitely slowed down my progress.
    Serial #9158
    Senior Member DavidW's Avatar
    Stevensville, MD
    Louver opening looks great, looks like that didn't take to much time either.
    Jacob's Avatar
    Rogers, AR
    Quote Originally Posted by DavidW View Post
    Didn’t take but 1/2 hr or so but does make a difference!
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Hydraulic brake light
    For more than one reason, decided not to use the brake light switch in the kit. I couldn’t imagine how I’d have to twist and turn if it needed adjusting...I’m too old and not flexible. The electric switch seemed to be very sensitive and I’ve had good luck with the hydraulic type.
    https://thefactoryfiveforum.com/albu...chmentid=81006
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Need info please
    For mounting the rear of the body I am using the modification with the threaded nuts rather than the long bolts provided... the spacer tube is 3.75 “, I am about 3/8” less than that to achieve the 3.75”...if I pull the body back to get this satisfied, the driver door hinge won’t open but if I satisfy the door latch area and door hinges, I’m about 3/8” under this...is this 3.75” critical?
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Got the body firmly mounted and fitting everything that will need to be drilled or opened up. Just like the pros said, driver door in on the front and out at the back, pass door in at both locations.
    Sorry for the pictures but I had to start using my iPad and this the only way I know to post pics. At the top corner of the door I assume most builders build that area up with HSRF and contour into the dark?
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Progress is slow but I’m attempting to mount everything I can think of prior to disassembling for paint. Putting off mounting the windshield for last.
    Levy 306
    T5
    2015 Mustang IRS
    Jacob's Avatar
    Rogers, AR
    Mini bear jaw door latches
    Since I wasn’t hearing much good about the FFR door latches and experience I had with having to pull while holding the latch on my previous hot rod, I decided to attempt installing the bear claw latches, so I could slam the door closed and stay closed. Have some more work to do to dress it up but here is what the passenger side looks like. Slams shut and stays!
    Levy 306
    T5
    2015 Mustang IRS
