Should I rivet the foot box from the inside out so it’s smooth on the inside for the carpet or from the outside in, so it looks better when the hood is open?
Mk4 ordered 1/3/18, IRS, Coyote, T56 Magnum
Smooth head on the outside. Be careful to use the right grip range rivet to minimize what's inside the footbox. Insulation (which I hope you're using) and carpet will easily handle and cover the secondary (crushed) head of the rivet.
BTW, good question and attention to detail. I've seen multiple builds with the "wrong" end of the rivet in full view. Using the domed side wherever possible for visible rivets looks much more polished and professional. Details add up.
2x on using the smooth side whenever visible. Also, if you are using any heat/sound insulation (coolmat in my case) it will nicely even up the bumps in your footbox and tunnel areas. So you won't see them in final carpet install.
Definitely go with rivnuts on wheel guards. It really opens up the workplace areaI needed to do some tweaking to my side pipes and it was very helpful ...next is my first engine oil change.
Any know if you can get the rivets (from the engine compartment side) between the footbox and the front tunnel and the upright on the floor panel when the engine (Coyote) and tranny (TKO-600) are installed ?
I would like to rivet these post install is at all possible (they are already pre-drilled)
Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
Ok thanks. So the only way to rivet the up-right (front) section of the floor panels is to do so prior to engine install, or pull the engine/trans or to rivet from the outside in(to the tunnel). Curious to know what approach you used?
For #8674, since it was my first build with a Coyote plus an early Gen 2 installation, I mocked up the engine in the engine compartment without any panels. Used that to determine the location for fuel lines, harness, PDB, PCM, etc. Then took the engine out, installed all the panels along with everything else, then put the engine back in. More is known now, and if you use one of the established layouts, you can install everything including the panels first. Then drop the engine in once. However you're comfortable. But bottom line I'd have the panels all installed except the DS footbox tops and outside, before installing the engine for good.
Thanks.
