44
161
BadAsp427
...and perfect timing, I was just starting my investigation of this.
One question, I have not done initial alignment of the rear wheels yet as I am still waiting on the e-brake cable and the manual says not to tighten bolts down until the e-brake step is done. Will this affect the steering rack setup? ...I see there is a step in there where a string is run from the rear wheels to the front.
Bradley
