Leaks. I am not fond of leaks. I spend more f****** time trying to get leaks to stop than I care to consider. I already replaced my entire fuel system to get rid of leaks. I replaced the front brake line (crossing the x frame) to get rid of a leak in the right front. I have a leak in the oil pan that does not want to identify itself clearly (it would be nice to have a lift for this one), and I have a leak in the large power steering tank-to-pump line that won't go away (bad fitting, maybe?). Other than that, all is good.
