Has anyone used and Oil Cooler in the stock location for a Power Steering Cooler? I'm considering going this route.
If so, did you go with the the Factory Five Setrab Cooler kit, went with another kit, or did you Fab up your own?
Thanks.
Thanks.
Mark IV Roadster #7679
Coyote 5.0, T56, Hydraulic Clutch, IRS, Torsen Diff, Wilwoods, Hydraboost, ABS Power Brakes, Power Steering, & tons more extras.
I did not go with an oil cooler because I believe Mark Reynolds at Breeze automotive told me it wasn't really necessary for this application. (If I just threw you under the bus, Mark, I apologize, and if I am wrong, please educate us both!!) EdwardB used a cooler in at least his 20th Anniversary build, perhaps the earlier one as well. Check out his 20th Anniversary thread for more info on location and brand. Sorry I don't remember the exact post number.
@Jazzman, thanks. I saw what Paul did in his build. I remember he had a smaller remote cooler. I'm doing a Coyote build and was going to utilize the factory oil cooling connections on that motor that route to the radiator. My inquiry here was to see if anyone re-purposed the oil cooler in the factory location for their power steering instead. Thanks again.
I don't really feel that a PS cooler is necessary for a street car although it won't hurt anything. I do track work with mine and installed one after finding how hot the fluid gets with sustained high RPM runs. I just a simple 3 row transmission oil cooler---you can see it here:
Yes, on the return line. The supply line is quite high pressure and there is no reason to stress it.
If you have a remote aluminum reservoir that will radiate significant heat too and lessen the need for a cooler.
I agree with Jeff K that for autocross a cooler is a good idea.
I have to replace my power steering pump after about 5600 miles and my guess is that it failed because of excessive heat so this time I am going to and a oil cooler to remove the heat. I drive mine 75 to 100 miles at a time so the fluid gets pretty hot
I’m thinking about one something close to the link below and mounting it similar to the radiator over flow tank
https://www.summitracing.com/parts/sum-331018
Rick
I did use an oil cooler for my PS cooler. Made use of that opening up front.
Like this one...don't remember the size I used...there are several
https://www.summitracing.com/parts/ear-41300erl
Use a temperature sticker to determine if there is a temperature problem.
https://www.summitracing.com/int/par...ts-1/overview/
I have seen several over the years out in the front opening. Use one similar to the one Sanford linked so the shape is similar to the old oil coolers so you can run the lines up into the rad opening like back in the day.
http://www.superformance.com/Default...BoCsc4QAvD_BwE
I went a different direction on my Coyote build. I simply used an extra long return tube and coiled it into a spiral of about 3 turns of 12" in diameter. I mounted the coil behind the radiator around the fan motor. This allows the air that has passed through the radiator (warmed, I know) to pass around the tubes and cool the fluid. There is much more tubing involved than in the small oil cooler I bought and once the tubing is painted black, it is hardly noticeable in the engine bay.
I do not plan on auto crossing much if any and the solution will keep the fluid temp more reasonable.
Larry Johnson
Colleyville, Texas (DFW area)
2016 Mark IV complete kit
Delivered March 3, 2016
New 2016 Roush Coyote engine w/453 hp
2016 IRS, Tremec T600 mid shifter
I had the same thoughts. Keep in mind, the FFR Setrab cooler is set up for -10 AN fittings. The high pressure power steering lines are much smaller. You can make it work with reducers but you will need to play with the hoses and fittings. I figured the big -10 lines coming off of the cooler were a big part of the look so changed my plans. It can be done but you need to plan it through.
I have one like the one shown in the link posted by Rick that came from Levy with my engine and power steering setup. I don't have it mounted yet but it will go on the frame between the engine and battery, this is on a Gen 3 coupe. The cooler is plumbed in on the low pressure side and I will be using 6-AN fittings.
David W
I used one in my Coyote build.
