Thanks Thanks:  46
Likes Likes:  16
Page 8 of 8 FirstFirst ... 678
Results 281 to 302 of 302
Thread: Steve's MK IV Coyote Build
  1. #281
    Senior Member Fixit's Avatar
    Minneapolis 'Burbs
    If I were to do it again, I'd keep those handy little access panels in place.
    You must not be a subscriber to Mr. Murphy... As many of us know there will never be a fuel pump or sender problem when the tank is empty!!
    John D. - Minneapolis 'Burbs
  2. Likes Straversi liked this post
  3. #282
    Added Sanpless Tonneau Cover
    I've been wanting to get a Snapless Tonneau from Phillip and Kay Deal for a while. I emailed them and they sent me a measuring guide to ensure a great fit.
    I marked out my dimensions per their instructions, but I realized my high-mounted seatbelts were going to cause an interference with their cover.
    I mocked up a possible solution on butcher paper, turned it into a dimensioned drawing and sent it to Kay and Phillip with photos. I asked if they would do a custom cover. They said they would be happy to accommodate my request as soon as the holidays were over. I was in no rush.
    A few weeks later the cover arrived, perfect fit!
    I also sent them a sketch of a small flap and asked them to make and ship loose so I could install after everything was in place.
    Worked like a charm.
    It was a true pleasure to work with Phillip and Kay. Great people and a great product.
  4. Likes Mark Eaton, PeteMeindl liked this post
  5. #283
    Senior Member Kmcallahan's Avatar
    Jul 2019
    Midland tx
    Steve,
    Your Design and their build came out great. that is a good looking cover.
  6. Thanks Straversi thanked for this post
  7. #284
    BadAsp427's Avatar
    Greeneville, TN
    Phillip and Kay do a great job with these covers. I will tell you that when you adjust your bungee cords, adjust them TIGHT. If you leave them too loose, and it is raining, they will puddle and not drain the water off. The first time mine was in the rain, the cover worked great, but the puddle was almost disastrous. I found the by having them tight, the water would flow off much better rather than puddling.
    Not tight enough, any longer without draining it off and I think it wold have collapsed.
    With them tight, you get something like this.
  8. Thanks Straversi thanked for this post
  9. #285
    Thanks, that’s good advice. I appreciate it
  10. #286
    New Bling
    Someone posted the link to these new Coyote coil covers from Ford Racing (M6067-M50CAM). I like the raised fins in natural aluminum.
    Couldn't help myself.
    I like the look and I hadn't spent any money on the car recently and that's just not right...
  11. Likes GTBradley liked this post
  12. #287
    Nov 2018
    Centennial, CO
    That is a perfect addition!
    Bradley
  13. Thanks Straversi thanked for this post
  14. #288
    May 2018
    Park City, Utah, USA
    wow - yeah, that does look good!
    2018 Factory Five Mk IV, Gen 2 Coyote, Tremec TKO 600 5 speed, complete kit, standard brakes and rear axle;
    Delivered: 5 Sept 2018
    First start: 31 Aug 2019
    First go-cart: 22 Sept 2019
    Basically done except paint: May 2020
    Graduation: June 2021
  15. Thanks Straversi thanked for this post
  16. #289
    Very nice. Those are great looking covers and fit into your very nice engine installation perfectly. Now if only Ford would have something like that for the Gen 3 Coyote. If that's even possible.
  17. Thanks Straversi thanked for this post
  18. #290
    Elk Grove, NorCal
    Perfect
    Kit purchased: July 25, 2017
  19. Thanks Straversi thanked for this post
  20. #291
    Thanks all. Can’t even call it a project since they just snap on, but the result made me happy none the less. Paul, you are right, Ford should offer something for the Gen 3 but I think you handled it as well as can be. You just gotta see the beauty in those Gen 3 performance numbers and be happy.
  21. Likes edwardb liked this post
  22. #292
    Senior Member Caddy Dad's Avatar
    Jun 2019
    Scaggsville MD
    Cover looks great. Do you have any contact information for Phillip and Kay?
    Mk IV Roadster #9749, Kit received Jan 2, 2020, Blueprint SBF 347 TKO600 Holley Sniper EFI, Dual roll bars, IRS, 17" Halibrand, Nitto 555 G2 245, 315 Road legal Oct 20, 2020
  23. #293
    Quote Originally Posted by Caddy Dad View Post
    Phillip Deal
    [email protected]
  24. #294
    Aug 2019
    Spokane, WA
    Next up is the EdwardB's clutch switch bracket. All I can say is thanks and thanks again. Don't know what i would do if I was building this without the EdwardB build thread. I have it printed and in a binder.
    Hi Steve. Really enjoying your build thread! I've already documented a number of tips I will consider once my kit arrives, and I can start the build.
    I like you idea of printing Edwardb's build thread. I've read all of his build threads, and (like everyone else) really benefited. Is there an easy way to print like you mentioned above? I found the printable version option, but it doesn't include the pictures, which a man with a small mind (me!) definitely needs. How did you print his build for your binder? Page by page?
  25. #295
    Glad you found something useful in my thread. It's been a while so I don't remember exactly how I printed Paul's and others' but I just went to Page 1 of my build thread and hit "Ctrl" "P" and it looked like it was set up to print the entire 53 page document. I use Microsoft Office on a PC.
  26. #296
    Terlingua Racing Team
    I loved the Terlingua Racing Team emblems that Hotyacht added to his car in New Zealand. Loved the story he shared about the exploits of Shelby and his buddies out in the Terlingua desert. Reposted below.
    Copied from Hotyacht's graduation post. "The badge on the side is the Terlingua Racing Team logo as used by the Shelby team on their Mustangs - there is a great story behind the logo and how it came about - https://terlinguaracingteam.com/terl...-team-history/ "
    As much as I admired Hotyacht's emblems, I opted to pay tribute with a grill badge. Fabricated the backing plate and angle bracket and bolted the pieces to my radiator screen. I haven't made anything in a while and really enjoy making simple brackets with a jig saw and file.
    I like the look and I like to share the story.
  27. Thanks mike8082 thanked for this post
    Likes GTBradley, JB in NOVA, mike8082 liked this post
  28. #297
    Nice addition Steve. Looks great.
  29. Thanks Straversi thanked for this post
  30. #298
    Apr 2015
    Great thread. Thank you for
    your documentation! Can I ask how the finish on your aluminum panels is holding up? I really like the look of the brushed aluminum and would like to do something similar.
  31. #299
    Quote Originally Posted by ZachT View Post
    Thanks Zach,
    Glad you enjoyed the thread. I have several thousand miles on the car now and the aluminum panels still look great. I finished mine with Alumaclear. Others use Shark Hyde. Both products work great.
    Good luck with your build. Reach out anytime.
  32. #300
    7000-mile update and Shout Out to a great vendor.
    7000 miles and loving every minute. I changed the oil at 5000 and gave the car a thorough inspection. One loose bolt on my rear sway bar but everything else looked good.
    I had a rattle in my driver's side Gas-N-Pipes side pipe. I called Georgie to see if I could buy a replacement. He said he would just send me a new one. Didn't ask how long I'd had it; just said he'd replace it. Then Covid hit and stainless became scarce. Georgie got behind on his existing backlog so he asked if I could be patient. Of course, I understood and eventually Georgie sent me a new side pipe. Just a shout out to a great vendor! He was eager to help me but wanted to take care of all of you waiting for your orders.
    We are very lucky to have great vendors that support this community.
  33. Likes Chopper, 460.465USMC liked this post
  34. #301
    Glad you are still enjoying it!
  35. #302
    Senior Member Tooth's Avatar
    Nov 2020
    I'm really glad you posted this. I'm early on in my build and this amazing build just gave me some inspiration.
    Thank you!
  36. Thanks Straversi thanked for this post
