0
0
Coyote won't start...drat.
Hello guys,
I have my Mk4 to the "should start" phase and was all ready to post a triumphant start video.....alas, not so fast.
With the key turned to "on" I hear the fuel pump go on and I have 60+ lbs of pressure to the regulator. The "PCM" and "fuel pump" lights come on and when I turn to start the "start" light comes on the PCM. The engine cranks over quickly but does not want to start.
I have double checked the following:
The Neutral Safety Switch (blue/yellow) is well grounded.
The coyote 12v start/run (red/green) and (red/blue) wires are properly wired.
The blue clutch safety switch wires are connected together.
The coyote harness ground wire is run directly to the battery.
The gas pedal, MAF and O2 plugs are all on tight.
The battery is fully charged.
Any ideas or suggestions are welcome,
