Yes, that does help - thank you!I interpret the switched side as the backside of the switch, which routes to fuses. As opposed to the hot side of the switch which is fed 12V from the battery (perhaps via the starter post) As you note, the switch itself cares not which post you connect to :-) Hope this helps ...
