Filled the area with HSRF and sanded flush with the surface then used rage gold to finesse the surface:
Kept finding some raw gelcoat in about 4-5 areas so just decided I better grind out the seams. Interesting, the surface looked hard and felt hard, but when ground down, the passenger front fender had the most soft areas, so I had to be pretty aggresive, I kept finding pockets of raw gelcoat, Hopefully I got all of it:
Then initially filled these voids with HSRF and will sand this off in a few days, then come back with filler:
