I decided to modify the DS footbox. At 6'2" and with Kirkey seats, I found my right legs resting against the 45 degree bend in the stock sheetmetal..... not very comfortable. Did I mention by knees bother me and I want to straighten my legs as much as possible. Now the DS footbox looks more like the PS footbox. Also added Al's HNR (heat and noise reducer).
Nice work. That mod makes such a big difference for long legs.
I guess I'm surprised that you didn't have sufficient room, especially given that you have the latest version of the footbox sheetmetal. But, it's not my car... I'm a couple of inches shorter than you and I have enough room. Then again, I've been fortunate that my knees are still holding up It looks like you extended the inside wall mostly at the transmission end of the footbox?
Al,
With the Kirkey seat set-up I can't straighten my right leg out while driving. (The back of the seat, at floor level, is several inches from the cockpit wall. The seat tilts back a little, so you have to shift it forward so the top doesn't hit the body lip in the back). I still can't straighten my leg all the way but I not longer have the bumps. I started at the trans tunnel end... it tapers it in a straight line all the way to the gas pedal. Took the 45 degree bend out. It is a little wider at the gas pedal too.
ALSO: The new footbox adds width, not length..... I think
I so wish I had done this!! Good job. I'll bet that is a real improvement.
