10
25
Thanks guys! I was pretty sure that was going to be the answer. It does make sense. I sort of wondered when I combined the brake and turn wires if that would cause issues. I should have listened to the little voice in my head. (No, not the little voice that says it is always time for Pizza! NO It is not time for pizza NOW, it's 8 am!! HUSH! I am trying to work!!)
Edwardb, i believe you chose to use LED inserts from Watson's Streetworks on these lights. After seeing them, do you feel they are significantly brighter? Is there any change to the wiring if I decide to use them? I have some stuff to return to Watson's anyway, so I was debating just exchanging the parts I am returning for the LED inserts.
