9
David aka Ducky2009
Straversi
Ducky, before you cut, check to see if the adjusting nut is centered. On one of my UCA assemblies, the adjusting nut was spun down one threaded rod about 1/4" before any threads were engaged on the other rod. I don't know if it would have mad e a difference but it seemed like I would have less adjustment.
Steve,
I unbolted the adjusting link from both ends and screwed ends in all the way, then reattached. Still to long to achieve 7 degrees. Not sure what other people are experiencing.
Build Thread:
http://thefactoryfiveforum.com/showt...MK4-Build-9035
