Here is a cardboard template I made to see If I wanted to just get a second FFR fluid reservoir. I think the shape and size will work out fine. I am a bit concerned about the location, right over the headers, but that is pretty much where the manual says to put it, and where the CNC reservoirs would be anyway. The lids are level with the top of the frame rail, so they should not interfere with the hood. I'm not sure how this might interfere with wiring, but I plan to run the wireloom on the outside of the same frame rail, so it should not interfere. I will even use the same attachment points to both hold the reservoir bracket and the wireloom. What do you think? Have I missed anything obvious?
