Here is the after. Looks much cleaner:
Scott -
I can't tell you how appreciative I am that you posted this seemingly 'minor' lower rad pipe mount tweak. It's been bothering me ever since I discovered where that metallic rattle sound was coming from while under throttle. My solution was to wrap the pipe with rubber as you did but this solution is way cleaner. Thank you!
Also, the artist's rendition of your roadster is spectacular. Bravo!
RickP
