The enclosure was formed out of a single piece of 0.040" 6061-T6 Aluminium.
Mocked up the transmission to check for clearances. It is in first gear and there is plenty of room with the brake down.
Also, lots of clearance with the trans in 1st and the brake handle all the way up.
About 1/2" of clearance between the transmission and the enclosure with the transmission cover sitting slightly ahead of it. Plenty of clearance since the transmission will not move fore/aft due to loading. The front lower corner could be trimed and then closed up to give more clearance if required.
The mount was made up from a piece of 3/4" X 1-1/2" tube.
Enclosure mounts under the handle mount.
I still have to weld in a mount for the cables but that will be the same as the existing mount on the passenger side. Once that's done I will be able to determine exactly where the cable will exit the enclosure. The cables will be shortened to fit by swaging on new ends (found a hydraulic shop that can do that). There is plenty of room to run any wiring under the enclosure.
I have to get myself a metal brake one of these days!
Pics of the dash clearance:
And some pics of the enclosure out of the car:
Here are some updated pics of my parking brake mod. Almost complete except I still have to fabricate the access hole cover. Even used the leather boot that comes with the kit (modified). Need to put something on the handle to hold the boot tight against the handle. Had to make a new T-cable about 3" longer and shorten both rear cables.
Let me know what you think. I'm extremely happy with the way it's coming out.
Here's a copy of the bezel drawing. It was made from a piece of 4" x 1/8" 6061-T6. I got a 42" piece for about $12 CDN.
Here is a drawing for the mount. I'll post them for the enclosure and cable bracket when I get a chance to draw them up.
Here's the cable bracket.
Finally, here is the drawing of the enclosure (which is optional).
Black lines = Cut lines
Magenta lines = Bend lines (note the legend in the lower corner. Bend them in the right order and direction)
Green lines = Mark and bend lines only after fitting to car
Brown/Red lines = Construction lines - do not cut or bend)
Final product with custom billet handle and built in indicator light.
Parking brake off.
Parking brake on.
Cheers, Rod
Rod,
That is an absolutely flawless application, I especially like the indicator light built into the button head.
Bill S.
Instead of being part of the problem, be part of a successful solution.
HOW TO BUY A USED COBRA
Rod, glad to look over this again How necessary do you think the enclosure is? There is none used in the original location, and that looks to be the hardest thing to fab up.
Wow, now that is a nice Job, One of the cleanest e-brake Mods I have seen, Nice work!
Great idea ,and great detail. Thanks for sharing.
I had just thought of that not that long ago! I never liked the e-brake on the pass. side or just sitting on the trans tunnel, that does look quite nice. I personally would have the trim ring chromed, but it looks like it will go with your more brushed look. Oh and by the way this is my first post!!
I hope all you talented guys bring your Mod links over from FFCars. I believe I'll be on this site more and more. Thanks, Rod.
Texas Cobra Club-Austin
July 2009 FFCars Picture of the Month
FFR3542K, 347 C.I., EFI, T-5, 3-Link, Miata Front Sway Bar, Red with White Stripes
Great post and great pictures. I had been studying Morgans as they have done it the same way.
I was thinking about this a while back but decided not to do it. You've got me back into again.
I'll be out in the shop tomorrow thinking this out.
George
Nice work!
Couple of questions:
1) Any reason to not just reuse (cut and re-weld) the frame components from the original location? I like your fabrication you did, just curious though.
2) Are you guys using cnc machines to make the bezels? That looks to be the hardest part.
KD - Formerly beartoothweb
FFR#6407
Home 4/18/09 - Roller 12/7/09 - First Start 1/23/11 - First Official Go Kart - 4/10/11
Build Site
What I do to pay for it all - Web Design, Graphics, and Programming
Beautiful job!
My Saving Grace: John 3:16
FFR6687, Graduate #39 in the Class of 2009
The Factory Five Forum March 2012 POM
1) I never really looked at it but just of the top of my head I doubt it would work. The mount would have to weld in from the opposite side somehow and I did want it raised the 3/4" to position it where I wanted.
2) I made the first bezel (shown) by hand. It wasn't perfect (one slip of the handand ....) but pretty good. We recently had a water jet company cut out 2 for a buddy and I.
Thanks for the kind words guys!
Cheers, Rod
Parking Brake, Probe Turn Signal, Super Porting J-Pipes, Aerospike Mod, Taurus Light Switch
"Can you imagine?!"
I have to give dv/dt and JKleiner credit for the inspiration here. I wanted to move the eBrake handle to the top of the tunnel and I also wanted to use the parts I had on hand. Here is what I came up with. I used 2" x 1/8" angle iron and 1 1/4" x 1/8" bar stock to make my brackets.
My brackets hanging in my rattle can paint booth.
The rear bracket is just a piece of bar stock drilled and bent in a vice to match the 3/4" bar angle and mounted with a grade 5 cap screw.
jj
We're All Here, 'Cause We're Not All There.
