Results 1 to 30 of 30
Thread: Mk III Parking Brake Relocation How-To
    Member dv/dt's Avatar
    Ottawa, Canada
    The enclosure was formed out of a single piece of 0.040" 6061-T6 Aluminium.
    Ottawa, Canada
    Mocked up the transmission to check for clearances. It is in first gear and there is plenty of room with the brake down.
    Also, lots of clearance with the trans in 1st and the brake handle all the way up.
    Ottawa, Canada
    About 1/2" of clearance between the transmission and the enclosure with the transmission cover sitting slightly ahead of it. Plenty of clearance since the transmission will not move fore/aft due to loading. The front lower corner could be trimed and then closed up to give more clearance if required.
    The mount was made up from a piece of 3/4" X 1-1/2" tube.
    Ottawa, Canada
    Enclosure mounts under the handle mount.
    I still have to weld in a mount for the cables but that will be the same as the existing mount on the passenger side. Once that's done I will be able to determine exactly where the cable will exit the enclosure. The cables will be shortened to fit by swaging on new ends (found a hydraulic shop that can do that). There is plenty of room to run any wiring under the enclosure.
    I have to get myself a metal brake one of these days!
    Ottawa, Canada
    Pics of the dash clearance:
    And some pics of the enclosure out of the car:
    Ottawa, Canada
    Ottawa, Canada
    Here are some updated pics of my parking brake mod. Almost complete except I still have to fabricate the access hole cover. Even used the leather boot that comes with the kit (modified). Need to put something on the handle to hold the boot tight against the handle. Had to make a new T-cable about 3" longer and shorten both rear cables.
    Let me know what you think. I'm extremely happy with the way it's coming out.
    Ottawa, Canada
    Ottawa, Canada
    Ottawa, Canada
    Here's a copy of the bezel drawing. It was made from a piece of 4" x 1/8" 6061-T6. I got a 42" piece for about $12 CDN.
    Here is a drawing for the mount. I'll post them for the enclosure and cable bracket when I get a chance to draw them up.
    Here's the cable bracket.
    Ottawa, Canada
    Finally, here is the drawing of the enclosure (which is optional).
    Black lines = Cut lines
    Magenta lines = Bend lines (note the legend in the lower corner. Bend them in the right order and direction)
    Green lines = Mark and bend lines only after fitting to car
    Brown/Red lines = Construction lines - do not cut or bend)
    Ottawa, Canada
    Final product with custom billet handle and built in indicator light.
    Parking brake off.
    Parking brake on.
    Cheers, Rod
    Husband/father/son mrmustang's Avatar
    Greenville, SC
    Rod,
    That is an absolutely flawless application, I especially like the indicator light built into the button head.
    Bill S.
    Instead of being part of the problem, be part of a successful solution.
    HOW TO BUY A USED COBRA
    Bourne-Cape Cod, MA
    Wow, now that is a nice Job, One of the cleanest e-brake Mods I have seen, Nice work!
    Ottawa, Canada
    Quote Originally Posted by mrmustang View Post
    Rod,
    Bill S.
    LOL Bill, I was forced to have a light by the safety inspection guys during my first inspection. The fact that the handle sticks up right in front of you didn't appease them.
    Cheers, Rod
    Greenville, SC
    Quote Originally Posted by dv/dt View Post
    Cheers, Rod
    Innovations like yours are the driving force behind the FFR kit and community as a whole. That plus necessity is truly the mother of all inventions, keep up the great work.
    Bill S.
    Rod, glad to look over this again How necessary do you think the enclosure is? There is none used in the original location, and that looks to be the hardest thing to fab up.
    Jeff Collins's Avatar
    Greensboro, NC
    Great idea ,and great detail. Thanks for sharing.
    Wichita Kansas
    If you don't live in the Great White North it's probably not as critical Rich!
    Didn't Rod do a super job on this? I love fellow engineers. One of these days I'm going to get around to doing the Fiero handbrake mod on Naga. I'll take a shot at documenting it for everyone too, but dang, Rod's set the bar really high. I'll have to do mine in Catia.
    d
    Ottawa, Canada
    It may have been overkill in hindsight. The only thing I don't know is what the air pressure would do to the leather boot without the enclosure. It's strong enough to lift my cup holders out of the trans cover at about 65 mph but the handle would be down so the boot shouldn't have anywhere to go.
    Cheers, Rod
    Junior Member fastlane82's Avatar
    I had just thought of that not that long ago! I never liked the e-brake on the pass. side or just sitting on the trans tunnel, that does look quite nice. I personally would have the trim ring chromed, but it looks like it will go with your more brushed look. Oh and by the way this is my first post!!
    Ottawa, Canada
    Quote Originally Posted by NAGA View Post
    d
    LOL, yeah, it helps keep the snow from coming through!
    Pfafftown, NC
    That looks amazing, just like all your mods have.
    Inspired by Rod I did the same only without the enclosure. No Ill effects in ~10,000 miles. I made a bezel and was able to use the FFR supplied boot.
    It is one of my favorite and most useful mods.
    Thanks Rod!
    Creedmoor, Texas
    I hope all you talented guys bring your Mod links over from FFCars. I believe I'll be on this site more and more. Thanks, Rod.
    Texas Cobra Club-Austin
    Southport, NC
    Great post and great pictures. I had been studying Morgans as they have done it the same way.
    I was thinking about this a while back but decided not to do it. You've got me back into again.
    I'll be out in the shop tomorrow thinking this out.
    George
    Senior Member Kevin Davis's Avatar
    Big Sky Country
    Nice work!
    Couple of questions:
    1) Any reason to not just reuse (cut and re-weld) the frame components from the original location? I like your fabrication you did, just curious though.
    2) Are you guys using cnc machines to make the bezels? That looks to be the hardest part.
    KD - Formerly beartoothweb
    FFR#6407
    Home 4/18/09 - Roller 12/7/09 - First Start 1/23/11 - First Official Go Kart - 4/10/11
    Build Site
    What I do to pay for it all - Web Design, Graphics, and Programming
    Senior Member Cobradavid's Avatar
    League City, Texas
    Beautiful job!
    My Saving Grace: John 3:16
    Making it up as I go. JJ in Cbus's Avatar
    Columbus, Ohio
    I have to give dv/dt and JKleiner credit for the inspiration here. I wanted to move the eBrake handle to the top of the tunnel and I also wanted to use the parts I had on hand. Here is what I came up with. I used 2" x 1/8" angle iron and 1 1/4" x 1/8" bar stock to make my brackets.
    My brackets hanging in my rattle can paint booth.
    The rear bracket is just a piece of bar stock drilled and bent in a vice to match the 3/4" bar angle and mounted with a grade 5 cap screw.
    jj
    We're All Here, 'Cause We're Not All There.
    Ottawa, Canada
    Quote Originally Posted by Kevin Davis View Post
    Nice work!
    1) I never really looked at it but just of the top of my head I doubt it would work. The mount would have to weld in from the opposite side somehow and I did want it raised the 3/4" to position it where I wanted.
    2) I made the first bezel (shown) by hand. It wasn't perfect (one slip of the handand ....) but pretty good. We recently had a water jet company cut out 2 for a buddy and I.
    Thanks for the kind words guys!
    Cheers, Rod
