10
25
Originally Posted by
SSNK4US
One more flywheel comment..... Might want to replace the flywheel and pressure plate bolts since they've already been torqued/stretched... Bolts are cheap.... Compared to the consequences......
I don't disagree. As bolts go, however, those are not cheap! $47 at Summit! Oh well, the cost of learning I suppose. Does anyone else concur that replacement of the flywheel bolts is a prudent decision? Any dissenters?
