Just found this diagram for the 2017 Coyote. The 2017 (from Ford Racing) has a vacuum line from the rear vacuum tank to the front on the PS, show in the diagram with the red illustration line being attached to the vacuum port. The vacuum lines are capped.....Where the blue electrical connectors are plugged in. (The 2015 shows existing vacuum lines).
