Results 1 to 29 of 29
Thread: First Go Kart!
    Northern VA
    First Go Kart!
    It happened! My awesome wife helped me install the mechanical throttle linkage yesterday morning. It then quickly dawned on me... I have a working gas pedal.... I have a working clutch pedal.... and theoretically, my brake pedal should work. So I tightened up some lug nuts, steering wheel, and ziptied some wires back and took her (the car, wife videoing) on her maiden voyage. I was shaking out of sheer excitement. Thanks everyone for all your help thus far.
    I still need to do an alignment, temporarily mount the dash so it doesn't come at me when shifting, and wrap up a few wiring odds and ends. Then I can actually go kart it.
    https://www.youtube.com/watch?v=zHYcHrT6gM0&t=4s
    Awesome! Congratulations.
    --Nathan
    Oct 2014
    Vermilion, OH
    Congrats!!!! Looks and sounds great.
    CVOBill
    Northern VA
    Quote Originally Posted by silver_pilate View Post
    --Nathan
    Thanks man!
    Northern VA
    Quote Originally Posted by CVOBill View Post
    Thanks Bill!
    Music To My Ears So It Must Have Been A Symphony From Your Seat!
    A Big Congratulations From Camp Go-Dad-Go!
    Northern VA
    Thanks Steve. It was a huge rush. Reminds you to respect the machine, always.
    Congrats on reaching that milestone. Looking good! You will be finished before you know it.
    Northern VA
    I hope so. I'm almost out of rivets hahaha.
    Congratulations! That beast sounds great!
    Northern VA
    Thank you Boyd. Its out of an 01 mercury mountaineer. All I did was a B 303 cam, valve springs, and converted to carb.
    Kearney Nebraska
    Congrats!
    Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022, First start 6/13/2024
    Serial #9158
    slpro1207's Avatar
    Moorpark, CA
    Congratulations on reaching this milestone. Sounds like a real beast. At this point you can almost feel the finish line. It will be done before you know it.
    MK4 delivered 2/24/2017. Complete kit #9023,IRS, Power Steering, Leather, heater, 17" wheels, sway bar ft & rr, tremec 600 and Gordon Levy Racing SBF 427. First start and go kart 8/19/2017. Graduated 1/15/2018
    MK4 #9230 complete kit delivered 1/27/2018. IRS, PS, leather, Tremic 600, SBF 427. Graduation 10/15/2018
    MK3 #5253 donor bought unfinished. SBF 331, T5 Trans.
    Hey ScottieC,
    I watched your video again and it really sounds healthy.
    What are your engine combination and cam specs if you don't mind me asking.
    Northern VA
    Hey ScottieC,
    Sure thing Steve. It is a motor I got from a junkyard for $450. It was pulled out of a 2001 mercury mountaineer with 47,000 on it. So it has the gt-40p heads, I installed a ford racing b303 cam, new valve springs to accommodate the lift, and converted it to carb with the an edlebrock rpm intake manifold and quickfuel 600 carb. I got just about every part from Mike Forte at Forte's Parts Connection. His advice was invaluable while shopping for everything.
    The trans is a T5 I got for $150ish, then rebuilt it.
    EDIT: here are the cam specs. https://performanceparts.ford.com/part/M-6250-B303 It doesn't have a ton of lift, but has healthy duration
    Quote Originally Posted by scottiec View Post
    The 1st Factory Five I got a chance to ride in had a healthy 302 in it and it made my daily driver feel like a Toyota Corolla. For the record my daily is actually a 1995 LT-1 ZF 6 Speed Corvette so you get the picture. Your car will be thrilling and scary enough to make you respect it.
    Northern VA
    The 1st Factory Five I got a chance to ride in had a healthy 302 in it and it made my daily driver feel like a Toyota Corolla. For the record my my daily is actually a 1995 LT-1 ZF 6 Speed Corvette so you get the picture. Your car will be equally as thrilling and scary enough to make you respect it.
    That is good to hear. I have been unsure what to expect with this combo, although it is a popular one the hp and tq numbers are all over the place. I see a lot of guys on here with a lot more motor as well. I come from racing spec miata, which is a very low horsepower car. So I am sure this will feel like ludicrous speed to me LOL.
    I do plan on dyno tuning it. Before that I will enlist the of CraigS (I haven't told him that yet. I still owe him lunch though!) to get the carb tuned as best as we can before dyno time.
    Sounds GREAT!
    Congratulations Scott!
    Northern VA
    Sounds GREAT!
    Thanks David!!!
    Congratulations. Way to go!
    RJD's Avatar
    Northern Virginia
    Congratulations Scott. Love watching that machine take shape.
    Northern VA
    Thanks RJD. Much appreciated.
    Fairfax Station VA
    Congratulations!
    But next time close the trunk.
    MK IV Roadster #8631
    Northern VA
    Congratulations!
    LOL John. And ill use my turn signal next time.
    Senior Member Lowrod's Avatar
    Nov 2015
    Mount Olive AL.
    Cool, congratulations!
    Thats a B303? Sounds great. Look forward to seeing a real drive!!
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Excellent, sounds great. Mike Forte put a B303 cam in the 347 I got from him.
    JR
    Ohio
    Congrats. Nice work. Sounds great.
    JRL16
    Northern VA
    Thanks guys!
