For those of you that have already dealt with the problem of the Willwood clutch pedal hitting the 3/4" square frame member, what solution did you choose?
- Notch the Willwood Clutch pedal
- Remove a section of the frame and weld or bolt a new structural piece to the outside of the 3/4" frame member.
- A alternative solution. (Please post your solutions to this problem.)
Thank you for your opinions.
