Results 1 to 8 of 8
Thread: Windows 7 file issues
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    If I look for a file using explorer (left pane) I can't see the file created by this computer but if I open file from the program (right pane) that created the file I can see it. Why is this happening?
    Senior Member Steven K's Avatar
    Denver, NC
    The one on the right shows "all supported files" next to the file name box. I am guessing the one on the right does not.
    Steve K
    FFR 3906
    Junior Member John Hudson's Avatar
    Riverside, CA
    Well, it looks like your "show file extensions" is turned off, which it does by default, so I can't tell what kind of file it is. It probably is a "system" file.
    Try this. Go to Control Panel > Folder Options and then the VIEW TAB
    Uncheck the box next to Hide extensions for known file types
    Click on the radio button for Show hidden files, folders and drives and see if it shows up
    Member dv/dt's Avatar
    Ottawa, Canada
    Wayne, if you click on the drop down list at the bottom right that says "All Supported Files" there may be an option to show "All Files". If there is then select that and the file should show up. Not sure the program will be able to do anything with it since it says it's not supported but worth a try.
    Cheers, Rod
    Super Moderator oldguy668's Avatar
    Rod, I think you have it backwards (or I do). The file does not show in the explorer window but it does show in the File>Open dialog.
    "Loyalty to the country always. Loyalty to the government when it deserves it".
    Mark Twain
    Ottawa, Canada
    Quote Originally Posted by oldguy668 View Post
    Brain fart, in that case I agree with John and it is likely a system file of some sort (or at least the computer thinks so).
    Administrator
    Enterprise Alabama
    I don't know, if I use the "open file" from the writing program and right click and send it to a USB drive. If I copy it back to the documents folder from the USB drive it appears. If I try to attach it to an email, the file that I copied from the USB drive in documents shows but in in original folder where it was created in and doesn't show.
    Member Rob J's Avatar
    Miami, FL
    I recently got a new machine, so I've gone from XP to Windows 7. It has been an adjustment period, and while I like some things on Windows 7 over XP, it frustrates me often, and I do miss XP. Seems to me like some of the simplest tasks to accomplish on XP are overly complex on Win. 7.
    SOLD MY MK III Oct 4. 2010
    1987 Buick Grand National (All original with only 16k miles on it)
    1965 Buick Riviera Gran Sport (Currently undergoing a complete Frame off restoration)
    2005 Ford F150 FX4 Supercrew (Daily Driver)
    2001 Dodge Grand Caravan (Beater)
