Valin's Custom Cars
bobl
That should make one wicked ride! I met you at SEMA and we talked big blocks for a while. I'm real curios to hear some specifics on this engine. I've built many big Chevys, but nothing bigger than a 565 on a standard deck block. I assume it's a Dart block and 4.500 inch crank? What length rods?
Hey Bob! Yes, it was nice talking to you! Blueprint uses their own block design, and yes it's a 4.5" stroke. I'm not sure what the length of rods are, but I will ask for you.
Some specs for you:
598 Cubic Inches. 4.6" Bore, 4.5" Stroke
10.0:1 Compression Ratio
Aluminum Heads, 119cc Combustion Chambers, 358cc Intake runners, 125cc Exhaust runners, 2.3" Intake valves, 1.880" Exhaust valves
Hydraulic Roller Camshaft: .647 Intake/.647 Exhaust Lift, 258/266 Duration at .050. 112 degree lobe separation.
My Victor Jr. Intake Manifold off my old motor
My Quickfuel Q-950 carburetor
