Results 1 to 40 of 43
Thread: Dash is done...pics too!
    Junior Member vRAE's Avatar
    Kelowna, BC, CA
    Well, the basics are done. Still have to tidy up the wiring, but here it is:
    Speedhut Revolution gauges from left to right: Water Temp, Oil Pressure, Tach, Oil Temp, Volts, Fuel Level and Speedo below.
    Other things on the dash: LED for variable speed fan on a temp sensor (the item on the very left hand side), Signal, High beams, Alt indicator lights and a Probe signal flasher. Top row of switches: Headlights, Fog lights, Hazards, Courtesy lights. Bottom row: Dash Dimmer, Horn, Ignition on/start, Accessories power, Wiper. The labels are from dashdecals.com stuck to stainless steel washers and the glovebox and dash vinyl is from acroadsterinteriors.com.
    I'm using ISIS to wire the car and using their remote keyless security setup so there won't be a key on the dash. I have a couple of other hidden security items too. I'm installing a console that has the matching clock, seat heater switches and the heater controls installed.
    Thanks to Jim (Kelownacobra) who helped with the Probe signal placement and also hooked me up with a company that cut the dash locally. I learned a bunch while doing this part of the project and still made 2 mistakes, but I'm going with this version for now. At this point, the wiring is next...
    Andrew
    Member 03SC's Avatar
    Fleming Island Fl.
    WOW, that looks awesome. Really like the black bezels on the gauges.
    MK3.1 Base Kit non-donor
    Levy Stage 5.5 408W, Levy Super Alloy Plus T-5, Levy DA shocks, Wilwood 6/4, Levy Comp Bump Steer
    Levy Billet Front LCA's, Levy Custom headers/sidepipes, Levy narrowed rearend, SAI mod, Northracecars 17" Team III wheels.
    Build pics:
    http://s239.photobucket.com/home/03SC
    Junior Member Kelownacobra's Avatar
    Kelowna, BC
    That looks great Andrew! What do you have to the far right of the dash(beside the gauge)? Are you using just the one signal indicator? I think I need to stop over for a better look.
    Jim.
    Member F5RSN8K's Avatar
    Gainesville, Florida
    Great looking dash. I love the gauge layout and switchs.
    MKIII 4330RD 306 Carb,T5Z,355 3 link,Team III w/Kuho Ecsta XS.
    Delivered 10/04
    Graduated 06/06
    Class of 2006 #30
    I'd rather die while I'm living than live when I'm dead!!
    Junior Member ratdog's Avatar
    Mills River,NC
    I also like the layout
    MKlll FF#5501 427w Roller,TKO 600,Hydroboost Brakes,Heidt's Adjustable PS valve, 4 wheel cobra disc,355 gears, Moser axels,ISIS Intelligent Multiplex System ,heated seats.painted by (NCPAINTER)
    Senior Member canuck1's Avatar
    Victoria, BC CANADA
    Chicks dig Km/h
    Dash looks very sweet!
    Sean
    MK 3.5 roadster (MK IV body retrofit to MK III chassis) 396W stroker, 4 bbl mass air EFI, QH (self-tuned), AFR 195CC Renegade, XE274HR, GP 4-1-4 SS headers, 3link, 3.73, 15" Halibrand replicas, SAI mod, bumpers, 2 X roll bars, IČ electronics, PS, hydroboosted brakes: 95 GT front, custom MK VIII calipers/Cobra discs rear, FFR front, Levy rear LCA's, Forte front, VPM rear bars, CF dash, mod comp layout w/Auto Meter Ultra-Lites, Lucas tri-bar headlights, coupe taillights, painted by SRP (again!)
    Member dv/dt's Avatar
    Ottawa, Canada
    Nicely done! But 300 KPH might be optimistic.
    Junior Member 68fightenfordfan's Avatar
    AK
    Sweeeeet Great job, love the guages.
    Senior Member OttawaFFRer's Avatar
    Ottawa, Canada
    looks great!
    10 years after my roadster build....
    289 FIA (pickup 28/08/20 if covid permits)
    currently building a 289 and accumulating parts needed to finish a Canadian Kit.
    Senior Member astglenn's Avatar
    Rescue CA
    Great layout. Looks super.
    Senior Member NicksPapaw's Avatar
    Knoxville TN
    I really really like your dash! I don't think I have seen one like it. Great job!
    MK 3.1 #6422, Complete Kit, 340hp Ford Racing Crate Engine, WC T-5 Trans, 3.55 Rear, Barcelona Red Mica Metallic, Silver Stripes
    WOW! Impressive!
    Loveland, CO
    What type of vinyl did you use? The foam backed material that comes with the kit, or something special. It doesn't look too "puffy" like some with the FFR vinyl.
    Ralph.
    Senior Member Geoff H's Avatar
    Edmonton, Alberta
    Looking great Andrew. Nice clean work. Looking forward to seeing it in person.
    Geoff
    Kelowna, BC, CA
    Thanks guys!
    The design is very similar to what CobraDVM did on his magnificent roadster. I have "borrowed" more than a couple of things from him for my build.
    Quote Originally Posted by rponfick View Post
    Ralph.
    I got the vinyl from Alex at acroadsterinteriors.com. He sold me the glove box and enough vinyl to cover the dash. He actually sent some foam backing as a separate item that I also used. Total thickness is less than the FFR supplied foam.
    Geoff - there's always room for you to visit! <grin>
    Member cChrisM's Avatar
    Ramsey, NJ
    Looks great. I was not a fan of the foam behind the vinyl but yours looks awesome. I guess a little less is more. Would covering in leather with the glove box be difficult? I know the glove box comes covered in vinyl. Thanks,
    Kelowna, BC, CA
    Quote Originally Posted by cChrisM View Post
    Thanks Chris,
    I'm pretty sure that CobraDVM purchased the leather for his dash and sent it to Alex to have the glovebox covered in leather too. Hopefully he will jump in here. In the meantime, here's a link to his dash thread:
    http://www.ffcars.com/forums/showthr...highlight=dash
    Andrew
    Bedford Hills, NY
    Quote Originally Posted by 03SC View Post
    I second that sentiment. Nice Job.
    Member Indy14's Avatar
    Indiana
    Very nice and neat job.
    Build Website
    Mk4 7276 Complete Kit; Delivered; June 28, 2010; Roller: November 30, 2010
    First Start: December 11, 2010; First Go-Kart: January 2, 2011
    Ford Racing 306 crate; Carb; Trans: T-5Z; 3-Link; Traction Lock rear end; 3.55; 15" Halibrand; PS/PB
    Very nice.
    FFR cobra
    RCR Superlite
    RCR 917
    04 Cobra/Z06/Diablo/bunch of other junk
    33 Hot Rod Builder geoffav's Avatar
    Enterprise, AL
    I love the gauges. It would be cool if the hot rod dash was removable.
    Junior Member peffem's Avatar
    Maryland Eastern Shore
    I like that, very nice.
    Helicopter Wrench-Bender ChopperJustin's Avatar
    St. Georges, DE
    well done
    "Gravity, It's The Law"
    Member Howard's Avatar
    Las Vegas
    Hey Andrew - that looks awesome (although I might be a little biased on the layout!). The black gauges look really good.
    Chris - I sent Alex the leather pieces that he requested, and he put them on the glove box and then sent it to me all finished.
    I really enjoyed doing the dash work - it was one of the real fun parts of the build.
    Howard
    (AKA CobraDVM)
    Kelowna, BC, CA
    Thanks Howard! Clearly your dash served as the inspiration for mine. I hope my blatant copying of your work is taken as a compliment.
    I too enjoyed building the dash as the results are fairly dramatic in a short period of time (relatively).
    Andrew
    Quote Originally Posted by Howard View Post
    Howard
    (AKA CobraDVM)
    Las Vegas
    Quote Originally Posted by vRAE View Post
    T I hope my blatant copying of your work is taken as a compliment.
    Absolutely I'm flattered - most of my build is an amalgam of ideas I've pinched from other builders anyway!
    Senior Member Todd Baumann's Avatar
    Howell Michigan
    Nice Job, The black bezels is definitely different and you don't see that very much.
    Todd Baumann
    FFR Build School Instructor 16+ Years Mott Community College
    FFR 2086 MKI, 22+ years on the road
    FFR 300 MKI Coupe
    Stratham, NH
    Black on black looks great.
    Still getting used to everyone's new avatar names!
    Senior Member AZPete's Avatar
    The dash looks great! Like you, I put in a locking glove box but then I was annoyed that I could not open unless I had the key which was on my ignition key ring. So, I added a press-to-open latch (Lowes). Unlocked, it opens and closes with a press, but I can lock the glovebox when parked.
    Did I mention I love your dash?
    Pete
    Junior Member Finallygotit's Avatar
    Vail, AZ (Tucson)
    Andrew, I like your dash with the black bezels. Nice job!!
    Andrew,
    Can you give me some info on what you used, and how you install the turn signal switch?
    Member sbak's Avatar
    Dallas, Texas
    Great looking gauges, great job!
    Dallas, Texas
    Mar 2014
    Pass Christian, Mississippi
    I tried dashdecals.com and could not locate them. Is this the correct name. Thanks and your dash looks great.
    MK IV complete kit delivered August 21st, 2014. Ford Racing 427w with X heads. IRS. Upgraded Wilwoods, 6 piston front and 4 rear. Tremec t600 and Ram Dual clutch. Holley Terminator EFI.
    Calgary, Canada
    Neat job. I don't like dashes with too much padding so your gauges have a sunk in look. You nailed it.
    Quote Originally Posted by pcww View Post
    Me either. The thread was started over 4 years ago, and the OP hasn't been on the forum for 4+ months. So I'm not expecting an answer.
    To the new question about the Probe turn signal, do a search on the other forum. Several threads.
    Dallas, Texas
    I would like hear about your electronics in more detail: the remote start and security systems. If it's not too much trouble.
    With respect to DaleG who passed this on to me, here is the link to a keyless entry/security system that he used, and now I plan to use it: Keyless ignition: http://www.digitalguarddawg.com/.
    Senior Member E-Ticket Ride's Avatar
    Huntington Beach, California
    Extremely similar layout to what I am currently planning. Different gauges, and thinking CF for the covering.
    Congratulations on a job well done!
    CL
    Confidence: The feeling you have before you truly understand the situation. FFR 7652 Mk IV Base Kit w/IRS: ordered 10/19/2011; Arrived 11/19/2011. Coyote, Trans & headers Installed 9/11/17. First Start 12/19/17, First Go-cart 3/2/18. Aligned and go-karting. Working the interior now. Happy customer of FFR, North RaceCars, Forte's, and Breeze.
    Chris Lewis
    Member olda4guy's Avatar
    Jan 2015
    Great Falls, VA
    Andrew,
    Congrats on the dash, it looks fabulous. Hoping I can get mine to be somewhere close to that.
    Jim
